Hello Everybody,
I am currently running into a problem. I set up a python script outside of VC and I want to send data from there as a continious stream to VC to simulate real Data input via TCP with Python.
I set up a Server (external script) client (script in VC) setup that works perfectly fine outside of VC. In VC, the funcionality of the client is still given, but it freezes the screen and the simulation can not be seen by the user while the transmission is going on in the background (sometimes also the “processing” alert pops up). The script runs perfectily fine if used outside of VC
Is there a smart way to work around that/improve the performance? I guess it is a performance issue right? I tried to create a work around with non blocking or multi threading, but don´t seem to be executed the expected way in the stackless python environment.
Attached you can find the client code. The client receives a dictionary (pickeled) and a header with the given length of the transmission.
import sys
import pickle
from datetime import datetime
import socket
import select
HEADERSIZE = 10
sim = getSimulation()
app = getApplication()
def OnStart():
global s
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
# Connect the socket to the port where the server is listening
server_address = ('localhost', 4000)
print('connecting to %s port %s' % server_address)
ret = s.connect_ex(server_address) #BLOCKING
if ret != 0:
print('Non Blocking - failed to connect!')
print('Non Blocking - connected!')
s.setblocking(False)
def OnRun():
global s
# Wait for incoming messages
full_msg = b''
new_msg = True
inputs = [s]
outputs = [s]
print("Waiting for Input from Server Python Script in Jupyter Hub")
while inputs:
# print("Waiting for Input from Server")
readable,writable,exceptional = select.select(inputs,outputs,inputs,0.1)
#for s in writable:
# pass
for s in readable:
msg = s.recv(1024)
if new_msg:
if msg != b'':
msglen = int(msg[:HEADERSIZE])
# print(f"new message length:{msg[:HEADERSIZE]}"
new_msg = False
else:
inputs.remove(s)
s.close()
print ("Socket wurde geschlossen")
break
full_msg += msg
if len(full_msg) - HEADERSIZE == msglen:
#print("full msg recvd")
# print(full_msg[HEADERSIZE:])
d = pickle.loads(full_msg[HEADERSIZE:])
#print datetime.now()
print (d)
new_msg = True
full_msg = b''
for s in exceptional:
print('Non Blocking - error')
inputs.remove(s)
outputs.remove(s)
break
