I want to use T-Axis as a servo, what are some ways?
Please show me Python Script source, too.
Hy @hooyoung,
what you mean with T-Axis?
I think you should try an assembly.
Maybe you could try with the “IO-Control” Wizard:
Oh Thanks. How Can I use that working 10 times? just use signal?
It depends on what you want to do. You can use signals in a robot programm or a process node with a “SendSignal” statement to activate it. That’s the easiest way. Or if you have something specific in mind, you can also use a Python script.
I don’t know the pros and cons of each method, so I can’t decide what situation and how to work. Thank you for your advice!
