Staübli 2 robots
could someone please tell me, how to send a number from one robot to another using Val3 Programming language, can we send information with DIO SET-GET?
I don’t have VAL 3 reference guide atm, but if you are using SRS you should be able to access that. With the Stäubli connection to VC, you should be able to use routine variables in expressions. I believe the Assign Variable statement in VC is converted to “writeSetProperty” in VAL3.
