Statistics Failure
I would like to see the distribution of the broken time and the repair time of a ProLathe machine.
I generated a statistical chart to show the percentage of time the machine is broken and in repair. However, it doesn’t display the percentage of time spent repairing. You can see in the simulation that only the Idle, or the percentage of time the machine is broken or busy, is mentioned. However, there is no red area indicating that the machine is being repaired.
Also, when parts arrive in a running machine, they go straight to the sink instead of waiting in the machine for repair and then being processed. Do you have any idea why?
FailureStats.vcmx (706.1 KB)
Thank you!
Hi, because it is set to auto-repair, there will be no “Broken” state, as it will directly repair, changing stats.State = ‘Broken’ to stats.State = ‘Repair’
Restart VC to update eCat or execute this .exe under VC installation folder to update eCat manually
Updated components
  1. /eCat/Components/Colchester/Machines/3000L.vcmx
  2. /eCat/Components/Feeler/Machines/EH-320.vcmx
  3. /eCat/Components/Feeler/Machines/FMH-500.vcmx
  4. /eCat/Components/Feeler/Machines/FTC-150.vcmx
  5. /eCat/Components/Feeler/Machines/FTC-350.vcmx
  6. /eCat/Components/Feeler/Machines/FVT-450.vcmx
  7. /eCat/Components/Feeler/Machines/NV-800.vcmx
  8. /eCat/Components/Feeler/Machines/TC-20.vcmx
  9. /eCat/Components/Feeler/Machines/VMP-32A.vcmx
  10. /eCat/Components/Goodway/Machines/GA-2000.vcmx
  11. /eCat/Components/Haas/Machines/EC-400.vcmx
  12. /eCat/Components/Haas/Machines/ST-30.vcmx
  13. /eCat/Components/Haas/Machines/UMC-500.vcmx
  14. /eCat/Components/Haas/Machines/VF-1.vcmx
  15. /eCat/Components/Hurco/Machines/VM-1.vcmx
  16. /eCat/Components/Tongtai/Machines/TVL-40.vcmx
  17. /eCat/Components/Visual Components/Machines/Generic 3D Printer.vcmx
  18. /eCat/Components/Visual Components/Machines/Parametric five-axis lathe.vcmx
  19. /eCat/Components/Visual Components/Machines/Parametric Gantry Machine.vcmx
  20. /eCat/Components/Visual Components/Machines/Parametric Lathe.vcmx
  21. /eCat/Components/Visual Components/Machines/Parametric Vertical Mill.vcmx
  22. /eCat/Components/Visual Components/Machines/Process Machine - Big Lathe.vcmx
  23. /eCat/Components/Visual Components/Machines/Process Machine - ProLathe.vcmx
  24. /eCat/Components/Visual Components/Machines/Process Machine - ProMill.vcmx
