Why is it that when the Stacker Crane has two outlets and I set a lower number for the priority of the conveyor below, it takes the first product to the conveyor above?
What I mean is, how can I make the pink boxes palletise in the opposite order?
If you use separate processes, you would need to add some constraints to these processes. I mean, the bottom process must be done first, and only after that is finished you can accept items in the middle, and so on.
Alternatively, if you could do this with just one process, you can use the Transport Pattern in, or multiple Transport In statements to different frames.
Couldnt you just simply switch the three Frames that are located for position 1 2 and 3?
As such the delivery is done to Frame 3 2 then 1?
