I am hoping someone in this community would be able to help/give advice on a problem I can’t seem to get around. I am trying to load one process node at a time with 3 pieces of an assembly and then rotate the table to load another node.
I had every thing working perfect with just the one table but after I added the second table the robot loads the wrong parts for the first table and then only loads one part on the second and continues to only load one part from then on.
I’ve tried setting the priority in the flow editor and reserving the resource, neither of which seemed to work.
Any advice or comments would be greatly appreciated as I have banging my head against a wall trying to get this to work.
Thanks in advance!!
