After changing the software to Chinese, I cannot customize the stop time here. No matter what value is set, it will always jump to stop at 24 hours.But using English is normall.
The bug has been fixed.The following is VC support’s reply:
In the File Explorer, Address bar, type %LOCALAPPDATA% and press Enter and then delete the IsolatedStorage folder.
Repeat step 1 but delete the Visual Components folder. This will remove your local eCatalog files, logs, and your configuration for the Visual Components product.
