i need to to a “simple” Optimization of a Processmachine with a simple buffer solution for autonomus work. As i though it’s an easy task with VC PM. As i started I’m frustrated that i can’t get it to work properly after quite some time.
I can set the routing rules to bring the assemblys (palett & products) to the process but i can not make i work to transport out empty palets out and bring it to the “conveyor” buffers. I did also not found a similar demo layout.
yes the shuttle conveyor is the best solution in your case.
You need to use “Two Way Conveyors” to act as buffer, a standard conveyor won’t work. You can add a process on top to stop the parts and change the conveyor direction by sending a signal before the Transport Out. If needed, you can add a Wait Signal to be sure the product left the conveyor before requesting a new one
wow this was fast. Exactly that what i needed. Is see that i lack some knowledge to use the signal properly. I will dig into you file, but for sure you saved me quite some time allready
Hi @Tilma, is there a way where we can set the capacity of this Two Way Conveyor as buffer? I tried setting the conveyor capacity 3, but doesn’t work. I tried Buffer statement with capapcity 3, but somehow break condition does not work even if the variable becopmes true.
