Hi!
I have a question about this problem:
In my simulation, two workers fill a buffer tank that supplies a production system via an autonomous robot. Now I want to simulate that these two workers stop working after an 8-hour shift, but the system continues to run autonomously.
How can this problem be solved?
It worked!
Thank you so much!
I also need tools like this to control manual work hours and schedule shifts. In the actual production process, the shift of workers is much more complex than this. I hope that such components can make the simulation process more realistic.
@lanmeng , maybe this post can help you:
Thank you very much, this layout is very close to the function I need. The difference is that I am trying to do it in the process of workers’ shift change, the equipment will not stop processing, which is a little difficult, if you have such components, I hope you can share with me. Thanks again.
