Several processes in one process node
Hello, I have a question about several processes within a process node:
I have 3 products (black, red, yellow) with different delay times.
I have assigned a boolean feature to them in the Product Properties and then process them with Reserve Product and Filters.
Everything works as it should, I have 3 different Processes in the Process Node.
But now my question is whether the whole thing could also be done in a Process without a reserve Product.
My idea was a query for the Boolean feature and then an If loop, but I can’t quite get any further, maybe someone can help me, thank you very much
ServeralProcesses.vcmx (294.5 KB)
  • If you already use different product types, you don’t need a property to differentiate them : you can get the type of the product which entered with “ProductIn.ProductType.Name”
    Here is an example with a switch statement, but you could also do it with an if statement:
  • if you only need to change the delay value according to the product type, you could also add a property to each product and use it in your delay by setting its TimeSource on “Expression”
ServeralProcesses2.vcmx (311.3 KB)
Perfect, the 2nd case with the switch statement is exactly what i am looking for. because i have to insert a setup time within the process for a yellow part.
Many thanks :slight_smile:
one additional question can i also work with the switch statement if several flow groups are running in the process?
Yes, it would work even if your products are in different flow groups
thanks for the quick reply, i will test it in my large layout and get back to you if necessary :slight_smile:
