Setting Product Properties, Filtering via those Properties
Hello all,
I am trying to filter how various products flow through my processes via using Product Properties/ Component properties.
Quick outline of relevant process steps:
  1. Random part created and assigned a color + part style (100+ different permutations or I could make a flow group for each)
  2. Part ‘inspected’ and then assigned an updated color and part style if it fails inspection
  3. Part moved to rack based on color and part style
The Product Properties shown are all integers with no constraints.
When I call them in the ‘inspection’ process mentioned above, i.e. Delay: ProductIn.InspectionTime, the statement works and does not have any errors, however the same property used as a filter does not function.
When I try to assign a property in the process node, I get the error ‘Part Creator:::SetPropertyStatement: Unable to assign value to Part.Style; the property does not exist’
And when I set the filter for the racking portion, I get the error ‘Process Node #23::ProcessExecutor::Rack Load::Transport Pattern In error: Property not found: Style.’
Ideally I would like to find a way to correctly write these properties and use it as a filter, or filter purely off of the color and ProductType of the part.
Thanks,
Hello, may I ask if you’ve managed to resolve this issue? I’ve encountered a similar problem.
Probably too late to help, and I cannot remember how I solved this particular application, but here is how I would go about it now.
I would create the ‘Style’ variable as a Component property instead of a Product property. Product properties are not filterable in transport in statements, or other functions like Routing Rules.
Component properties are addressable through an assign statement in the process node with an additional .Component, so in my original use case, I would have swapped/added the variable to Component properties, and addressed it “ProductIn.Component.Style”, rather than “ProductIn.Style”
Hope that helps someone in the future!
