Hi there!
Does anyone know a way to set the material of a robot’s trace using Python?
Thanks!
Hi there!
Thanks!
This sample code is for default trace setting, when line set is stored in robot root.
from vcHelpers.Selection import *
import random
app = getApplication()
def OnRun():
  materials = app.Materials
  materialCount = len(materials)
  while True:
    lines = filterGeosets(comp.UserGeometry.GeometrySets, VC_COMPACTLINESET)
    if len(lines) > 0:
      line = lines[0]
      line.Material = materials[random.randint(0, materialCount - 1)]
    delay(0.1)
            Thanks! This didn’t work initially, but then I set the Node (in the Actions Configuration → Trace On menu), because it was blank, and then it worked.
