I was wondering if any one has the issue when using one of 2 functions (Set node Material and Change Type functions) and generate PDF simulation report.
The functions work properly during the simulation (the color or the type of products change correctly as defined in different processes) BUT when we generate the PDF simulation report, the color/type of products are changing randomly!
I remember having some issues with this also. Have you tried replacing those statements with Delete/Create? So instead of changing a part, you delete the old one and create a new product.
Hello Este, thanks for the idea! It works fine but I still don’t understand why set not material and change type don’t works correctly in PDF simulation.
Any way thanks a lot for your help.
Sounds like either a bug or limitation of the PDF recording functionality. You should report such issues to VC support.
