I have two robots, but only one has a program.
I make a small program on the other robot.
I delete that robot.
The first robot no longer works.
Did you copy paste the 2nd robot from the 1st robot? In that case they share some properties so, I don’t know if it is the case, but it might be that this causes the problem;
To find out you can drag the robot in twice from the ecatalog and try again
