How can I invert a conveyor sensors signal to be true (1) as the default value and false (0) when something is detected?
I want the conveyor sensor to be connected to a motor on another conveyor, when the sensor is blocked I want it to tell the motor to stop until the part is no longer blocking the sensor.
Hi @CS_IRL
Modifying the standard components requires either a Professional or Premium license.
The logic can be modified in the python script by inverting the signal value.
Another option that does not require any modifications is to use the Boolean Signal Inverter found in the eCatalog Misc. category.
Hi Este,
Thank you very much for the fast response the signal inverter worked perfectly.
