Sending products back in the production line based on failure
Hi Visual Components Forum,
I’m currently building a layout of a production-line with a lot of manual processes. In the line of processes there are two stations where fails on the product can happen. IF fails happens on the products in these steps, the product needs to be taken from the present module and back to another module further back in the line and go through the same processes again. My question is, how will I do that with the standard process modelling?
I have seen in other posts on the forum that some uses filters to control the “split“ of good/bad products to different stations (parallel processes), but my challenge is that I need to send the product back in the production process based on failure state and I can’t seem to think of any obvious solutions to this. I have implemented product properties where the fail is written to and the logic behind statistically assigning fails to products based on specific failrate
I have attached example of how the overview looks like.
I have tried to setup my flowsteps in different configurations to make this happen, but without luck. I should add that I want it to be the same product because I am also monitoring the leadtime of the product. I know I could be creating a new product based on failures and send them back the line to go through processes again - and I will do this if I do not find a solution on how to do it with the “original“ product.
Are you already using the Get Flow Step, Find Flow Step, and Set Next Flow Step statements to send the product to different process flow step once the failure occurs and then just transport it out? It can go back or forward in the flow.
Additionally, the process visit count limits can be used to implement limits such as “product repair can be attempted 3 times and if still fails QA, just scrap it”
You can find an example of to use these statements in the layout “Return product to previous step in flow” in the Layout Templates in the eCatalog.
Thank you very much both, this is exactly what I’m looking for and I don’t know how I missed this functionality.
