I am making a demo about a process including a machine, sensor conveyor and conveyor. It works fine when the part stops at the sensor (OnSensorAction I chose StopPart) and the signal from sensor triggers movement of the machine. However, I have tried many ways but don’t know how to reset the signal so that the part can continue its path. In Process Executor tab, you can see that I tried to send FALSE signal back to the sensor but it does not work.
Thank you very much.
HI @thanhh019 ,
You could try using the “StopConveyor” mode for the sensor. After the machine process, send a True to the conveyor “PowerOnSignal”.
Thank you for your advice. I have tried it but the process still stops and does not resume (picture below).
I think sending 1 will not work, you would need to send “True” because it only accepts type Boolean.
This is the error I get if I send 1 from my testing
Process Node::ProcessExecutor__HIDE__::Process #1::Send Signal error: An error occurred while trying to get the value from the expression: Unable to cast value of type Integer to type Boolean
The problem is still not fixed. I am really confused.
use “True” with only capital T
So, Boolean type only reads “True” or “False” exactly as I typed
Thank you for helping me so much. It works now. However, now it is not in loop. As from the next part, I do not know why the process stops at WaitSignal. I wonder that maybe the signal is reset or something and is there anything to fix this?
From your image, I saw 2 errors in the WaitSignal statement:
- The correct Signal to use should be SensorBooleanSignal
- Put “True” to Condition setting
For the Process Executor tab, while loop is not necessary as the whole process will be executed repetitively.
