This .Net plugin helps to select all the dimensions from the Drawings tab to edit the dimension properties.
Tested in VC version - 4.6
1.Download and extract the Plugin.SelectAllDimension.dll from the attached zip file
Plugin.SelectAllDimension.dll.zip (2.7 KB)
2.Copy the DLL file to the Visual Components installation folder, eg:C:\Program Files\Visual Components\Visual Components Premium 4.6
3.Launch the Visual Components application. ‘SelectAll’ command is added under the Dimension group in the Drawing tab
To test the plugin,
1.Create a layout in the 3D world.
2.Goto Drawing tab, create view and add some dimensions.
3.Click ‘SelectAll’ command. All the dimensions are selected and you edit them from the Dimension Properties panel.
