If you are running the product on Windows and it appears blurred or the text and icons are too small, you can try to fix this on your computer.
Here is a helpful article.
https://support.microsoft.com/en-us/help/3025083/windows-scaling-issues-for-high-dpi-devices
A minimal approach is to use the automatic fix feature in Windows. After that, consider changing the display resolution of the monitor you use with the product. A direct approach is to use these properties.
About my setup: My laptop has 4K resolution, and I use these display settings.
My external monitor is different and I use the recommended settings for it. But the product itself will scale according to your display settings, so it is a matter of finding what’s right for you.
One thing about frame labels in 3D world, there is a Display option backstage in the product for changing the frame label size in 3D world.
