I have a question regarding the component Saw (Circular). After cutting a large blank into pieces (small block) why is the small block not stopping at the “FromConveyor” process node?
Thanks!
Kashif
Saw_Cutter_query.vcmx (47.3 KB)
Thanks!
Kashif
Because when saw cuts, it create new component, not PM product, that’s why only the last block(Original product from PM feeder) stops at the process node, you could try to use conveyor sensor to detect component, in process node, add WaitSignal statement, wait signal from conveyor sensor, then create new product, Assign product.Component.Length_X to 15.0, then transport out.
Thanks for your reply. But I didn’t get your suggestion completely because of my limited knowledge of process statements.
Saw_Cutter_query_v2.vcmx (335.5 KB)
Thank you very much, appreciated!
