Save Robot Program
Christmas is coming and everyone wants to save their robot programs so they can go and have peaceful Christmas holiday. Well here’s an add-on that lets you save and load robot programs in XML format.
Known limitations:
  • Topology paths (Premium) are loaded without rebuiling properties (select curve, smoothing).
version 1.01:
  • fixed future bugs on ElementTree null checks
version 1.02:
  • fixed bugs with property units
version 1.03:
  • fixed bugs with non-ascii characters
version 1.04:
  • fixed file format encoding to UTF-8
SaveRobotProgram_104.zip (6.0 KB)
Note that this is not a post-processor for real robot programs. This add-on is only used for saving and loading programs on robots in VC environment.
Hi
I believe I found an error with the openProgram.py script. On line 463 there is this code:
if unit_string:
    prop.Unit = app.findUnit(unit_string)
But the prop.Unit property appears to be read only so there is an error when it executes. I got it working for my case with this:
if unit_string == 'millimetres' or unit_string == 'inches':
    prop.Quantity = app.findQuantity('Distance')
elif unit_string == 'millimetres per second' or unit_string == 'inches per minute':
    prop.Quantity = app.findQuantity('Velocity')
Its not elegant, it would require quite a large if statement to catch every possibility. Not sure if there is a better way to implement it.
Thanks
Cool!
Hi Mike919,
Thanks for the feedback. It was a bug that I didn’t catch in testing. Unit is indeed read only and you have to play with it using Quantity property and setUnitMagnitude method. So now the code is like this:
unit = app.findUnit(unit_string)
if unit:
  prop.Quantity = unit.Group.Name
  prop.setUnitMagnitude(unit.Factor)
I fixed it in the OP attachment. Note that property value is always in the so-called canonical form (e.g. millimeters) and magnitude determines how the value is shown in UI. I tested this fix only a little but for distance types it seems to work.
