Can I start VC from windows command line? Furthermore, is this possible to start several VC instances together by running a .bat script?
Thank you!
Thank you!
for what?
The purpose is to run several experiments/simulations in parallel, and I can collect data after the simulations are done.
Thank you!
I’m not a profi with bat-scripts… but if I were you I would simply try it, if this would not violated the license terms of VC!
Thank you very much!
Hi @juergenb thanks for sharing the bat file! This will open the Models in different instances of VC but what would be the command to also start the simulation?
I think, you couldn’t do this via bat-script because this happens with VC-Framework in the specific VC-Instance!
Therefore you need another approach…
You could create an addon that automatically starts the simulation if VC is launched with a certain argument.
