I can’t put the product in the rotating platform to achieve the purpose of rotating the product with the rotating platform
Put a Frame and a ComponentContainer into the Node.
Location of ComponentContainer is the Frame.
After putting the Component to the right position, you need to grab the component with the ComponentContainer and then the Component is attached to the ComponentContainer. You can have more than one Component inside the ComponentContainer. So if you have many Components, you could still use one ComponentContainer.
The alternative is the new Process Model, which could accessed via the Tab PROCESS.
