Hello!
I am an Visual components novice and have modelled a simple robot gripper using the tutorial. The gripper works and can grasp components. The problem is that i want the gripper to rotate around Y axis so i added i servo controller to that link and that also works. The problem is that the component that i have picked up does not follow the gripper when i rotate. How can i make the component follow the gripper when i rotate the gripper?
Any help would be appreciated.
I have attached an example project where the component stays in the air when i rotate the gripper.
testGripper.vcmx (134 KB)
