I was using a “Rotary Washer” machine for a bottle filling line. However, the machine was not delivering the bottle to the outlet (output conveyor) after 2.5 hours of simulation.
I created a simple version for testing with a bottle feeder, a rotary washer, and input and output conveyors. This model is attached. Could you please check the model and suggest any solutions?
Hi kashifm,
Thank you for the layout. We have tested it. Works in 4.10 but in 5.0 it does on not in 2h 16 min 34 sec, It does not take the bottle. And when it takes it, it does not give it away. We have some investigation going with some other bug, but this could be cased by same thing. We will update this issue when we get some fix.
Actually, I forgot to mention that I created this layout in Visual Components Premium OLP 4.10, and it doesn’t work as intended at the time you mentioned.
