Rotary Table
I know this is a very basic question but I want to use a rotary table but without attaching another conveyor. The products will come from a different linear conveyor and then the cartesian system will put the product to the rotary table. Rotary table will have 4 slots and as each slot is filled, the rotary table will rotate 90 degrees. I can’t figure out how to get the rotary table to work. Can you help me?
If you are not using it with conveyors, you should then use the Indexing Table or Rotational Axis which are in the file “Signal Positioners” in the eCat. You can control them using signals.
