Robot's program
Hello everyone! I encountered a problem: I used VC5.0 Prem Olp version and exported the robot’s program, which includes dat and src files, but when I tried it in Officelite, it got an error and the message format differed from the one taught directly in Officelite. Why is that?
It’s hard to get back to you accurately when the specific error reported isn’t stated.
For my personal use, there are quite a few problems with the current OLP code, one of the most introductory problems is that there is no default program header provided, dat is missing “DEFDAT PrName”, src is missing “DEF PrName()”. You’ll need to either preset a header format within VC or add it yourself afterward to fix it.
As for other issues, that’s another story, at least the welding part is kinda problematic at the moment.
Thanks!Here’s the thing: I also noticed the def issue. As you said, there are other issues. I don’t quite understand why, as a software under KUKA, VC also supports KUKA robots so unfriendly.
Hi there! When you are postprocessing programs to real robots or to systems that has been completely setup virtually, such as OfficeLite environments, in order to load programs in correctly, you would need to set up the necessary machine data parameters accordingly. These include the program headers, footers and syntax supporting the correct KSS version.
Different KSS versions in KUKA robots are very picky about the syntax, which is why there exists a lot of different parameters, options and postprocessors for generating the correct code out.
If you need further help on setting up your system, feel free to contact our support.
