Robot program statement through python
I have a question about making a statement through python, for start i know how to make add Motion statement for typical robot and how to adjust its position and parameters.
start = Routine.addStatement(VC_STATEMENT_PTPMOTION)
start.Tool = "TCP"
position = start.Positions[0]
position.Configuration = "cfx0"
position.PositionInWorld = comp.Pos_start
this is just my example from one of my tests. As i wrote, it’s working for basic e-catalog robot but i prepared my own 3 axis robot which has X and Z transitional axis an Z rotaitonal. I would like to achieve for python program to generate values “Rotace,Délka,Výška,Otevření” in PTP.
Except i dont know how to add these values through python and for now my code only does this.
with this code:
executor = comp.getBehaviour("RobotExecutor")
program = executor.Program
subRoutine = program.findRoutine("Place")
for i in program.Routines:print i.Name
def fillSub(Routine):
  #Routine.clear()
  #statement1 = Routine.getStatement(0)
  pass
if not subRoutine:
  subRoutine = program.addRoutine("Place")
  fillSub(subRoutine)
else:
  fillSub(subRoutine)
Any help would be greatly appreciated :smiley: .
run into the same problem
You can use knowledge of vcMotionTarget and its related modules to do this to create or modify the target object and joint values of a statement. Something like:
#The following code is an intercept I took from the relevant section, it is not directly usable, it just contains the few methods or functions that are needed.
mt = robot_cont.createTarget()
robot.MotionTarget.JointValues = temp#temp contains the set joint values
gt = robot.MotionTarget.Target
