Warning from ‘RobotController #33’: No robot connected.
Warning from ‘RobotController #21’: No robot connected.
Warning from ‘RobotController #26’: No robot connected.
Warning from ‘RobotController #13’: No robot connected.
Try to move a robot with his base towards the center of the robot transport controler. Use the PNP-command. When both components are very near a green arrow should appear. It points towards the robot controller. Move them closer together and the robot should snap itself onto the controler. When you select the controler then, there should be a green triangle instead of a yellow one. Also when you try to move the controller, the robot should move with it. If this applies to your robot, it is connected to the controller
