Robot Calibration add-on
Calibration is important when doing offline programming for robots. Standard tools in VC allow you to input tool and base frame values numerically and this enables you to sync real robot frames to simulation model. This Robot Calibration add-on adds few helper tools for cell calibration. Add-on has tools for part calibration and tool calibration.
Part calibration positions a simulation component based on measurements. You need two sets of measurement points, one from the real robot and another from the simulation robot. These sets are then compared and selected component is shifted based on the offset between point sets. LSQ fit is used to calculate the offset. There’s also a tool to import real robot points using a CSV file. Alternatively you could use robot uploader to upload positions if uploader add-on is available for that robot brand.
Tool calibration allows you to set position and orientation for a tool frame based on measurements. This is useful tool in cases where tool calibration is not available on the real robot and thus tool frame cannot be synchronized from real robot to simulation model. Instead tool frame is calibrated on the simulation model and then it could be synced from simulation to real robot.
There’s a video tutorial for both part and tool calibration. Links to add-on itself and tutorials are below.
Add-on:
RobotCalibration_13_09_2021.zip (6.0 KB)
Video tutorials:
https://visualcomponents.sharefile.com/d-sbd358150b0fd4dd788421419a16c3d01
Thank you very much!
Dear Keke
The Video Tutorials link on this page has probably expired. It says, “Invalid Link”
It will really great if you could share a new link.
I updated the video links so they should work again.
Thank you so much keke,
Yes they are available now.
Dear Keke:
Thank you for your tool, it is very efficient. I was wondering if it is also possible to calculate the robot base, sometimes the base will be near the workpiece. The robot demonstrates three points and then calculates a base. Is this possible?
Thanks!
This add-on doesn’t have 3 point method calibration for base frame unfortunately.
Hello! Is it still valid in 2026 in VC4.9?
Yes it should work in later releases too.
