[Resolved] How to Create a 360-Degree Continuous Loop Conveyor?
Hello, VC users,
I would like to create a conveyor that rotates 360 degrees, as shown in the picture, where the conveyor continuously loops around.
However, I was unable to achieve this using the Joint Types provided in Visual Components.
Is there a way to implement this?
Thank you.
You can take a look at this — it’s a classic example built with Link. By mastering the use of `move` and `moveImmediate`, along with the mathematical principles of circles, you can achieve the same effect.
If that’s too difficult for you, you could also consider another approach that purely uses one-way/two-way paths. Use a slider as a component and move it along a conveyor belt to create a similar effect. Of course, this means you’ll have to sacrifice some performance, but it will be less difficult.
Thank you. I didn’t know there was a component like this! I’ll take a look at it and use it as a reference. :slight_smile:
BR
you can also have a look at the “Carrier Indexing Conveyor” in the Advanced Motion file from the eCat
Hi, Tilma.
I apologize for the late reply.
Thank you for your response. It was very helpful :slight_smile:
