Replace Geometry With Original (according to its VCID)
Have you ever been struggling with missing geometries? Or accidently modified or deleted them and wanna get back the original situation of that component. Sometimes, the replacing the whole component is not desired and it might be big work to copy and paste the geometries node by node.
With this command you can replace the missing geometries with the original geometry from the component that can be found in your eCatalog with the same VCID.
-make sure that the component is saved and is found in eCatalog
-for this version features trees including frame(s) are not replaced
ReplaceGeometryWithOriginal_v1.0.zip (1.71 KB)
