Remote Desktop support
Howdy. Are you using VC 4.5 with a network/floating license? If so, go to File > Options > Display and look for “Software Rendering”. You can also find it in the app config file in your app data by searching for “softwareFallbackMode” and set it to true. If enabled, everything should work fine. Note that you need VC 4.5 or higher for this.
