there is a mode do force VC to reload Python cusom modules or packages
if they are been externally modified?
Or I need to close and reopen VC each time to do that?
Thanks
Luciano Cavallero
Flexcon s.r.l.
Thanks
Luciano Cavallero
Flexcon s.r.l.
Hi Luciano,
normally you can simply use the reload() method to reload a python module:
reload(myPythonModule)
br/Ralle
VC seems to cache various files that it accesses. Sometimes I find that attempting to reload only reloads from the cache and not the modified version. I suggest closing and reopening VC each time to get a clean slate. Test this by simply adding a print “version number” statement to your library when you modify it.
