Hi all,
I am attempting to write a works task that will read the boolean signal value ‘trigger’ on the task and conditionally do something if true or false.
Is this possible?
I understand there is WaitSignal but this won’t continue if the signal isn’t the value that I want. I need it to read the signal value in each iteration to see if the value is true or false.
I see in the documentation there is some kind of function for reading values and they put it in a conditional statement but not sure how to use this to read the Signal
Thanks.
