Libor
1
Hello to all once again.
I would like to read information from the components that are inserted into the assembly.
I have “String” property in product that I’m inserting into assembly and this I’d like to read.
Unfortunately result of my function is:
I also tested component properties and different types of it (string, bolean, integer), but always with same result.
Thank you for your help.
TSy
2
The created ArrivedProducts variable is probably not of type “product”, but maybe a “list of products” or something else.
If it is a list (array) you need to use the indexing syntax like ArrivedProducts[0].Prod == “A”
Libor
3
Thanks @TSy for your reply, but it’s still not working, I got the same output error message.
Have you got any other idea?
