I am new to Visual Components. In our school we have a hydraulic press and we can measure its path. I also made 3D model and import it into visual components. But now I want to read data from excel, but I stuck in the process. Can somebody help me out? First, I want to make that 3D model moves like the data in excel second If that would be successful that 3D model moves like a real one.
you get data in an Excel-File. → Save it as csv because it’s easier to read in…
find out the time difference between the measured data. (t=0;v=x1 | t=0.02;v=x2 | …) → timeSteps=0.02
code a import-method for your data
create boolean-signals for control when to drive your hydraulic press
Take the example script and make your version out of it…
def OnRun():
while True:
triggerCondition(lambda: getTrigger() == DriveMachine)
if DriveMachine.Value:
#Import waypoints here with your csv-import-method!!!!!!
for v in wayPointList:
valueZylinderpaar = float(v.replace(",", "."))
ServoController.moveImmediate(v)
delay(0.02) #Here is the timeStep!!!
