can anyone explain me this error and how to fix it? When i use any kuka robot and want to use RCS it causes this error. Could be some missing files? (Using KUKA.Sim 4.1)
Juicy topic of conversation. I have seen this. Try clearing “RobotDataGeneration” and then set “RobotDataFolder” to be empty, and then run simulation. It might not work or at least give error that no machine data is in robot.
You might need to reinstall KUKA.Sim or install “EqualizingTech” which KUKA support can help with.
If you want to get down with the sickness, this zip is RobotDataFolder created in VC 4.6 +KUKA OLP with same KR 10 robot, but in VC it has dress pack on it. zhuhge1q.zip (512.2 KB)
There might be something corrupted on the installation, so best to contact Support since they can possibly send you repair package.
Might be related to Engineering Tools installed on your device… is it just KUKA.Sim on your machine or do you also have VC on the machine? Anyway, support most likely has to help or you can try cleaning your machine.
Solved. If anyone else facing this problem - it is in windows account special letters like ý,ž,á,… If I move the files RobotDataFolder somewhere else - its working. Lesson learned.
If i remember correct, its a problem with this:
(there is in name Spurný - ý - special letter which cause the problem with reading the robot data)
You have to create new account without special letters on laptop and reinstall it probably. Or somehow rename the main account.
Or there is another way little bit provisional. Robot will generate the folder in --appdata/Local/temp/Kuka Mada/“something” you have to open it, copy the “something” folder (in this example (“hhozk”) and paste it for example in C:\Users\ only. Now redirect the robot data folder into the new copied folder without special letter in pointer, so select C:\Users"hhozk". Thats it. It should work, but if I remember you have to do it every time you close the Kukasim or add new robot.
I had the exact same issue. However, if you don’t press play straight after you load the new robot, but you try to add something in the program code such as a PTP somewhere it works just fine.
