I found FANUC R-2000iC/270F of ecatalog can’t pick up anything.
So far ,the other robots are quite normal.
Is there a problem with the properties or behavior of this model?
How to modify?
How to modify?
I fix it!
The Accessories of Section is wrong.
the frame of section is set to none.
Change to RootFrame,and it’s normal.
If you find similar situation,try to check it.
