hello
i am wondering if i am able to generate a 2 components over each other
such as a box over pallet , which i can at the end of the conveyor let the robot pick the box separately and leave the pallet !
thanks in advance
hello
thanks in advance
You can use the Works library to create a pallet and box and then merge them. Afterward you split them in order to pick them separately, i.e. not as one component. Otherwise, you can use a Shape Feeder to create a pallet and a Pallet Filler component to fill the pallet with a box. Many different options as well.
