I am a user of version 5.1, using VC 4.10.
4.10 / 5.1 When saving while working, the screen freezes here as shown in the attached image, and only the layout file size increases indefinitely without saving.
This problem is really distressing. For example, if this issue occurs after working for 2 hours and saving, it would mean that all the configuration you have worked on so far is lost.
The original layout is 10MB, but when this issue occurs, it exceeds 3GB and cannot be saved.
Do you not know why this problem is occurring or how to fix it?
Was the file saved originally (or worked as) in 5.1 version which was then opened in 4.10 and then saved in 4.10? Going from old files to new generally works (backwards compatibility) but doing it the other way is not supported. The suggested way would be to start the project with one version and finish it with the same version.
Going from one major version to another can also be quite tricky.
This issue occurs regardless of the VC version.
This problem also involves a layout I’ve been working on in 5.1, and saving during the process causes an issue. If this issue occurs, the layout will not be saved, and all previously configured layout logic will be lost.
If this happens in one version only and without changing the versions in-between, I would recommend contacting support. If you obtained the license through a reseller please contact them for support.
This will most likely require checking log files etc. which should not be sent through forums.
