How to write a script to make the spindle rotate forward, reverse and stop according to the signal
- You can implement the function by modifying the following code
if sensorSignal(Customize the signal name).Value==True:
servo.setJointTarget(0,1400)
servo.setMotionTime( 6.0 )
servo.move()
I want the spindle to keep rotating after receiving the signal, not just for a few seconds.
What do i need to do?
Instead of IF, you can use WHILE to have continues rotation.
rot = 360.0
t = 1.0
while sensorSignal(Customize the signal name).Value==True
servo.setJointTarget(0, rot)
servo.setMotionTime(t)
servo.move()
servo.setJointTarget(0,0)
servo.moveImmediate()
You need to have that inside a While True loop. Now the program exits if the signal is False.
initialize...
while True:
while sensorSignal...
servo...
else:
delay..
