Python Error or Visual Components Error
Hello everyone,
Now, I’m using in Visual Components 4.10 version.
I have serious problem with VC.
when i write python script in VC, And when I save that script suddenly VC program is shutdown…
so I can’t save the layout, and all the work I’ve been doing is gone.
When using other versions of VC, there was no such problem, but it has occurred frequently since version 4.10.
Anyone else having these issues?
Best regards,
Merry Christmas!
No error messages? If there is an error message or something about your code, it might be possible to find the problem.
Merry Christmas BAD,
There is no error message because the program is suddenly forced to end.
Ok, if there are no errors reported, the problem will be harder to troubleshoot, are you comfortable sharing your layout or your code, as I haven’t encountered this issue so far. :melting_face:
The problem seems to be happening for no reason, not for any code, layout. Even if the layout is not large, writing and saving a simple Python code will shut the program down.
The reason for needing to simulate environments and code isn’t just to see if your environment is too big or your code is too long. When I didn’t have the problem, I needed your simulation file or code about what went wrong for testing purposes for error reproduction purposes.
If it’s really inconvenient, you can wait until after January 5, 2025 in Finland, when they are done with their Christmas vacation, and get it resolved by yourself.
