Pusher Conveyor - Outfeed Orientation
When I connect an outfeed conveyor to the Pusher Conveyor using PnP it orients it 180° in the wrong direction such that the outfeed conveyor interferes with the pusher conveyor. I have been manually rotating the outfeed conveyor by typing -90 in for Z-Rotation. It is then offset from the conveyor by about 150 mm. So then I move it manually so that it looks like it spaced properly.
So I get it to function, but it seems that the Pusher Conveyor has the outfeed port pointing in the wrong direction. What is the best way to correct this so that it maintains the proper port direction going forward?
Thank you,
Spencer
