Pull function
Hello, what is the best way to build a pull function in VC.
The following situation, I have a warehouse which is filled by forklift.
Now I want a process or buffer that pulls a product from the warehouse every 4 minutes, but this process should have the highest priority.
Can I simply add a TransportIn then 4min delay and then the next and the forklift this process as priority or are there leaner solutions for pull systems.
Thank you very much
I do not know if it is still relevant but with use of signals to recource controler you can reserve a resource for a certain task. And release it afterwards.
Somthing like this:
TransportIN
Sendsignal Reserve resource
Transport out
Sendsignal Release resource
Delay 4.0
