I need to simulate a hydraulic/servo press slide motion. Depending on the forming sequence the press needs to switch between different speeds depending on the press slide position. I would like these speed transitions to happen without deceleration in between. That means that I want to switch between two different speeds instantly and without the press slide “braking”.
From what I understand it’s not possible in VC to have zero deceleration if the motion doesn’t reach full speed, and a lot of times the press doesn’t reach full speed before it needs to change the speed.
Does anyone have a solution for how to achieve this behavior?
