when creating custom properties, is it possible to enable validation of property values like it is done in the Name property of e.g. bae frames (“Name must be unique…”)?
As an example, i would like to add a property to each routine of a robot and the values must be unique within the scope of the robot.
You would need to implement your own code that tracks creation and deletion of those IProperty objects and registers listeners for the value change event of each property. Then in the value change event handler you can do your own validation checks and show such an error message.
