My first post on this forum - been a user for good part of 8 years - only makes you realize that if you are not at it everyday ; you are basically starting from scratch lol.
I wanted to know if any of you have worked on a mechanism as in the video.
I am currently working with a mushroom manufacturer who is trying to retrofit his dutch trays.
The concept is you have 2 15m racks, with moveable rows ( basically a domino effect).
I managed to create the flow for the first set of processes. I am struggling as it involves lot of back and forth of products between the process nodes . I want the product to enter and leave the node only once - but what is happening is it tries to go into a loop.
I tried using the counter system by assigning variables etc - no luck.
Tilma, Thank you very much for this - I managed to find a resolution for this as well.
Will have a look at what you have sent now for reference.
So I basically,
created two process nodes for each rack.
Created reference frames for the rows and created them all together at once.
I then used signal statements to control the flow and the lift of the right rack which would move up n down.
