Poor performance
Is there no way to make Visual Components run better? I dont have that complex factory and the framerate is about 10-20 FPS. I’m not even talking about simulating anything, just using the software.
I have R5 5600, 32 Gb, RTX 4070, SSD.
When moving the view around, CPU & GPU use is only around 30 %, though it is almost 100 % on some CPU cores. Any ideas how to improve this?
The “shaded” view mode is generally the fastest, so you can try if there is significant difference between using that and the others. I think the “realistic with lines” is the slowest and some of the visual effects don’t scale very well to high resolutions, so the viewport can be quite slow on e.g. 4K screen even with decent hardware.
There is a FPS limit of about 30 as well in the viewport.
Thank you! I had not even noticed the view modes. I had just been trying to find any graphics settings in the options menu. Setting it to wireframe gave me usable fps, thought the 30 fps limit is still quite low.
