is there a possibility to attach a component (e.g. a gripper) to another component (e.g. a robot) by the plug ans play mechanism?
Best regards
Simon
Best regards
Simon
Jes with “OneToOne” - or “OneToMany-Interface”
Hi Captain_Feature,
thanks for your answer. Do you have an example for the plag and play function by the IOneToOneInterface and OneToManyInterface?
I try it wit the AutoConnect function with theAutoConnect method like this:
var simComponent1 = this.GetSimComponent("MyRobot"); var simComponent2 = this.GetSimComponent("MyGripper"); this.AutoPlugPlayService.ResolveParentToChildHierarchyConflicts = true; this.AutoPlugPlayService.UpdatePosition = true; this.AutoPlugPlayService.AutoConnect(simComponent1, simComponent2));
But it does not work.
Best regards
Simon
Â
Remember you are using the interface in the component to make connection. I would first of all get the interfaces in both components and then connect them. For example
var robot = App.World.Components.First().Behaviors.First(i=>i.Name == "Tool") as IOneToOneInterface; var gripper = App.World.Components.Last().Behaviors.First(i=>i.Name == "EOAT_MountInterface") as IOneToOneInterface; robot.Connect(gripper, true); IoC.Get<IRenderService>().RequestRender();
Â
Â
